Allen Bradley Sercos / Servo
iansmiler
Oct 2004
North America - For Now....
58
Okay gents, I have been given the task of using an Allen Bradley Servo Amp (Ultra 3000) and Motor controlled via a Sercos card (1756-MO3SE). I have no idea what the hell I am doing! has anybody got a tutorial concerning this topic or maybe just point me in the right direction, I'll appreciate any help I can get, Thanks,
Ian
Hi
Just a few questions
1 have you done motion on a control logix before
2 I think the card is a 1756-MO8SE
3 how many motors are on the system
Motion with the control logix and Sercos is as straight forward as you can get.The first time I used it I had only a few small problems.
Have you got all the parts and can you set them up on a bench.
Donnchadh K
In the RSLogix 5000 Help menu under On-Line books, study the "Motion Instruction set" and from the "ControlLogix Manuals", the Motion module volume.
I hope someone knowledgeable selected the drives and motors for you - properly sizing the system for the task is the critical first step in designing any servo system.
If you elaborate on the system operation or have some specific questions, you will get more detailed responses.
Hello All, I am using a 1756-L63 control logix controller of firmware major revision 16 which is having a sercos module 1756-M03SE with same...
3,683
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
137
420
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
113
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
787
