Bit transfer
sutton
Mar 2003
Singapore
74
hi all PLC experts,
im now doing a project where i have limited input terminals. so
i tried to reduced the usage of input terminals in operation
box selector switches.
my drawing will show you how the wiring is designed. so X2406 -
X2415 are my original plc inputs terminals. Y2803-Y2805 are my
outputs.
The numbers in my bracket is my operation box selector switches.
those will be my simulated inputs and worked like normal plc input
terminals.
so i tried to use 'bit transfer' function XFRB (62) in omron to make these inputs work. since i dont have a simulator, im not sure if i got this function correctly written.
i'll upload my mneaumonic code here(too big for ladder),please give me some comments.
thank you.
Hi eveyone. I need transfer signal from system 1 to DCS via modbus. System 1 only can send 32 bit floating point. DCS receive 16 bit integer. How...
20
10,601
Hi all, I was under the impression that Load and Transfer operate independantly of the RLO ? If this is the case the following code shouldn't...
9,112
I have an RIO network consisting of a 1747-SN, two 1749-ASB's with 48IO each, and a 1791-IOBX with 64IO. I have a steady green COM light on all...
3,571
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
284
A couple days ago I accidentally toggled an alwasyoff bit. The issue is it was set up as a single OTU on a rung, nothing else, and used as XICs...
226
