can't connect to PCI2000ETH
Have you:
- Activated the correct protocols?
- Correctly configured the PCI2000ETH card?
- Correctly configured the connecting partner's ethernet card?
- Correctly configured the subnet mask?
- Initialized the board?
- Created topic for the card to read?
Can you ping both the PCI2000ETH and the connecting partner when connecting a PC to the network?
For future posts/thread, please state the manufacturer of the device.
I'm guessing it's a BradComm Applicom card.
first thank you
before I used IP address can't connect the PLC
and I Last try to use ISO ,and it can connect to PLC
i don't the reason why can't use the IP
268
101
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
349
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
