CCW online monitoring
Jim G.
Nov 2007
Georgia
187
I have a system with a MicroLogix 830. It has a simple program with relay commands and timers. It was installed several years ago and programmed with Connected Components Workbench ver 9.0.
It has run fine. I just tried to hook up to it yesterday and could not get the software to show I/O status online. It showed "connected". Using a usb cable to connect to the PLC.
We have TechConnect, so they were called for assistance. Went through several steps including deleting some Harmony files. Still could not get online monitoring to work. Was told to upgrade to version 13 which I think is the latest. Have not done this yet, but will soon.
My question is, how does a system that was originally programmed with one version and has not been touched, suddenly not work when you go back into it. I remember being able to monitor this when it was first commissioned. We have changed nothing and I am using the same laptop and software that was used in the beginning.
What would make CCW fail to work later?
Could be almost anything. Registry changes, software installs, firewall changes, etc.
My "based on absolutely no knowledge" guess would be the usb adaptor is using a different/non supported com port, or there is a conflict somewhere with the selected com port.
Good Evening , I haven't done much with CCW and the Micro 830. I am trying to upload a unknown program from a Micro 830. It just seems like...
2,804
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
38
394
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
98
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
268
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
188
