CCW Pulse Timer
dhoyt1234
May 2013
manchester
I'm doing my first project using a Micro 830. For some reason I'm having trouble with what seems to be a simple pulse timer (TP). I cant seem to figure out what I'm not doing. I have the PT set to a time variable of 10 sec, Q is linked to DO00 but when I enable my IN nothing happens and the ET doesn't calculate.. What am I missing here?????
hmm yeah that's why I zipped both files because I wasn't sure what was what... Regardless though the program has nothing in it, I am really just getting a feel for everything. I tried just putting one rung down adding a direct coil for the enable to the TP added the time and made the output DO00. I don't know how it couldn't work...? I didnt have any problems building it or downloading it.
hi all, i want to control my stepper motor with my Delta dvp PLc,, how can i control pulses, steps and directions of motor though it,, thanks in...
1,779
my ccw softwer stops working when i add and try to open a ladder program.
36
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
38
468
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
121
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
279
