Compact logix and Festo ethernet
Donnchadh
Jun 2002
Ireland
1,004
Hi All
Has anyone connected a Festo CPX(or somting like it) valve block to a compact logix over ethernet IP. I have used them over devicnet and profibus and had no problems. I have connected a powerflex drive over ethernet and again this was no problem, and I must say I taught it was brill.
I am not sure but I think I need to use a MSG block butI am sure what I should put into Instace,Class and Attribute.
Any help would be great.
Donnchadh K
Donnchadh said:
Hi All
Donnchadh K
You configure the block in ethernet's I/O tree
data type will be created in Controller tags that are grouped as 8 bit blocks (SINT). Each bit is a valve
Hi
Thanks for that.I will be on site tomorrow and wil have a go at that.
Thanks again for the reply.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
112
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
120
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
207
265
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
142
