compact logix
Are you trying to control something or scale an input to some engineering units ( measured value). Output to what?
The SCP instruction is just a simple linear equation in the General Form.
http://en.wikipedia.org/wiki/Linear_equation
The ControlLogix has a Scale instruction in the Function Block Diagram language, but many users of the SLC-500 "Scale with Parameters" instruction prefer ladder logic, so this was one of the first Add-On Instructions that I saw created.
Search "SCP AOI" on this forum, or grab the standard Rockwell Automation version from the Sample Code website by searching for document 044714.
http://samplecode.rockwellautomation.com/idc/groups/public/documents/webassets/sc_home_page.hcst
You can also find it in the Sample Projects folder of Logix5000. Look for 'Add_On_Instructions_Sample.ACD'.
The path should look something like this:
My computer > C:/ > RS Logix5000 > Projects > Samples > ENU > Rockwell Automation
You may have to choose the version of Logix you have between the ENU and RA selections as well.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
124
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
134
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
208
267
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
143
