Configuring 1769 HSC in rs logix 5000
bhorn847
Apr 2014
dafter
Heres what im using
1769-L24ER-QB1B AB Compactlogix controller
1769-IF4 AB 4 IN Analog CompactLogix
1769-HSC AB High Speed Counter Module
1734-AENT AB 24V DC Ethernet Adapter
1734-IB8 AB 24 V DC 8 Channel Sink Input Module
1734-OB8 AB 24VDC 8 Channel sourcing Output Module
Now all im trying to do is configure the HSC to control 2 motors, the problem im having is i dont understand what exactly i need to copy into the modules for proper configuration. What i have in right now faults out the PLC and Major Fault 23.
Can someone shed some light on this for me? or point me in direction to solve anyways
Yes everything is new, upgrading from an SLC 500 and rs logix 500 for a school project to this new system. Everything had green lights and and running, i then went through all the calibration stuff from the Manual and now when i turn it to run mode it faults out saying 16#ff0b Module Configuration rejected.
Take out the HSC Module (including HSC program)
Download new hardware configuration for exisiting IO
look what happen
Thanks that seems to have solved my faulting issue, I still cant get the outputs in the HSC to do anything however
Hi folks...I need some help getting a 1769HSC configured correctly. Here is what I need, in specific: I will need to use a directional counter...
1,539
Hello, I am attempting to use the 1769-ASCII 2 Channel Module with a CompactLogix 1768-L43 Controller to connect to two AccuRange AR 700 lasers...
7,963
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
124
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
815
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
607
