Control logix -change cpu
It has been five years since you started this thread. Will you be upgrading the firmware to v20, or a newer version ?
What type of HMI devices or software does your system use ?
If you are just replacing a 1756-L71 with a 1756-L72 with the same firmware version, then you should have to change nothing in your HMI or your communication networks.
Hello Ken,
Yes Finally I have installed today and found no issues....Actually customer gave a green signal to install today after 5 years :)
Sandy
I have a control logix PLC that is controlling a few power flex 70's via a 20-comm e module(ethernet/IP). I need to migrate the VFD's to a...
3,608
Hi I have a need to change the PLC name (probably the ethernet card name) that is viewed inside rslinx during who-is. basically i have 2 with...
5,387
251
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
379
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
759
