Control Logix PI block
russrmartin
Aug 2002
Eastman, Wisconsin
744
Hello all. I've got an application where I'd like to use a PI block in control logix to control the % output of a drive. This will be my first attempt, and there are several values and terms of this block that I am unfamiliar with.
First off, the Wld option. According to the description this is: The lead frequency in radians per second. It affects the integral control algorithm.
My question is, how does it affect it? This is my main question. I was expecting to be able to set my process and control variables and start playing with proportional and integral gains. Before I do anything, I'd like to have a better understanding of how this block works. Any input is welcome.
Russ
I've used this block extensively for dancer control and web tension control. It makes life easy (well, easier).
From other experimenting I've done, Wld can be set to the inverse of seconds/repeat. ISA standard term is minutes/repeat, so convert to seconds and take the inverse (repeats/second).
I am trying to read the analog input card of a remote Control Logix over ENET, but can't get it to read.
5,327
R
Hello. I have a PID block in a control logix 5555 that is not functioning. The processor is acting like it is very bogged down, as it changes...
19,910
261
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
383
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
767
