Controltechniques MP dc drive
Altaf Belim
Jan 2004
karachi
27
Hi Every one
I want to know how get start with control techniques MP dc drive and convert mentor II parameter for MP drive.
Altaf Belim
You will need to determine which of the Mentor// parameters are different from default. Most of these are in %, 1000 = 100.0%.
The Mentor MP is mostly in real numbers, so the percentages will need to be recalculated to the real Amps, Volts, etc...
Other than that, CT tech support can help you out.
The software for both units is free. The cables are cheap, or you can build your own (pin-outs are in the manuals).
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
278
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
54
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
48
Hello everyone, my son and I are working on building a metal lathe. I been waiting for a motor/speed controller donor from a treadmill. I finally...
53
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
71
