conversion s5 to s7
dek7
Aug 2008
tuins
hello every body,i am new in conversion and in order to convert fb250 and fb251 (read /write analogic data) i want to know how can i implement fc105 end fc106 in source s7 ?
thinks a lot!
In Simatic Manager, select the FC105 or the FC106 block and hit F1 to get help.
If I remember correctly FB250/FB251 converted to integers. As FC105/FC106 converts to/from REALs, you will have to consider if you want to continue with REALs or INTs in the converted program. Then adjust your program accordingly.
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
204
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
88
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
124
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
105
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
284
