CPU 313C Encoder
iniquitous
Jun 2011
Hatay
Dear All,
I have Cpu 313C and I am working on a simple project.I need to use encoder in this project. I am using ladder. I used SFB 47 block and I wired encoder as I124.0=A ,I124.1=B I124.2=Z.
I chosed count continuous parameter.But counter always counting up.I change rotating direction of encoder it also counting upwards.
Please help for this events.
BR,
In the 2.4 Count slot properties, you can indeed select Count continuously.
But in the Count tab you need to configure how the Inputsignal will be evaluated. It should be configured as Rotary encoder.
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
124
Hi guys, I have CPU S7-300-313C ( Cat No - 6ES7-313-5BE00-0AB0) DI24/DO16 and AI5/AO2. when I am trying to configure and use the AO channel PQW...
2,564
Good day, Can you give me a link or a list of how built in i/o's have been distributed with the S7-300 CPU 313C. thanks in advance for your help
1,243
Hello, I am using step7 v5.5 and wincc flex 2008. I have created my PLC program have it working, but I am having trouble with my...
10,088
dear all ... i would like to ask a question.. Can mitsubshi (HMI) which install on pc can communicate with seimens PLC model 313c cpu.
2,097
