CPU615 and MC fault
dimigav
Jun 2009
Thessaloniki
34
I have a CPU614 (6ES7 614-1AH01-0AB3) and an MC EPROM card (6ES7 951-0KJ00-0AA0).
If I load the program to CPU works fine until power off. Then loses the program.
If I plug the MC card, the the SF led lit. They told me if the card contains different configuration than the actual, is a reason to give me SF fault. How can I format the MC card without PROMMER or PG?
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
47
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
127
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
92
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
100
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
116
