DeviceNet Scanner Scanlist Empty
daba
Jul 2004
uk
5,401
I am setting up a very simple DeviceNet network...
1756-DNB Rev 7.2 node 0 - displaying "A#00 NoRX"
1794-ADN/B Rev 2.001 node 2 - ModNet Status LED flashing red, IOStatus LED off, Power GRN
RSLinx version 2.56
RSNetworx version 2.21.00 (Build 27)
I can browse the network with RSNetworx - AOK - it shows me both nodes.
When I go to the DNB scanlist, nothing is showing in "Available Devices", so can't add the ADN to the scan-list.
I've never seen this before, has anyone else ?
Wait, wait: RSNetworx 2.21 ? They're on Version 10 now.
Because the FLEX adapters use a custom applet rather than an EDS-based parameter editor, it's possible that the older RSNetworx software doesn't have an applet to handle the 1794-ADN Series B adapter, and therefore doesn't think it's an available slave device.
Thanks for the heads-up on the revision, Eddie. Stupid me should have researched how far back it was - I even got it wrong - it was 3.21 not 2.21. Perhaps it was a typo, or a mental aberration. Anyway, on the two counts of incompetence, I am now serving 10 days holding my head low and hiding with shame....
Hello all, I'm trying to find out if it is possible to configure (download scanlist) an out-of-the-box 1769-SDN (AB devicenet scanner module)...
5,634
Hello, I have a device with 68 words input. But one block on the Devicenet Scanner is only 61 words. I am trying to map this device to 2...
546
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
572
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
990
Does anyone know the part number for that plug that plugs into the 1771 devicenet scanner? The manual just says it is a linear plug, its 5 pins.
1,064
