Display Servo Drive Alarms to HMI
Nan
Jul 2015
louisville
126
I am using a AB Kinetix 5500 EtherNet Servo Drive, I am wondering if there is way to display servo drive alarms to HMI?
Yes. Just read the status bits out from the drives. There are dozens of faults and alarms if you just look under the drive object in the controller tags tree.
Thank you very much! It does have dozens of them.... What would be the best choices if I only want some of them?
Continued
To add onto this, I am trying to do something similar and I understand there are lots of faults identified by the standard motion axis data tag, and that I could choose the ones I want but I'd rather pull all alarms in the cleanest way possible. My end goal is to use a multistate indicator on an HMI to show what fault is active on the Kinetix 5700 drive I have. But I don't want 100+ rungs pushing a different DINT value into a tag that I read off. And (though I may be missing it) I can't find any easy correlation between the ".CIPAxisFaultsxxxx" tag and the individual faults that effect the value of the axis faults tags. Any suggestions? I can explain better if needed.
Hello everyone! I have a machine with about 15 servos. On the PanelView on that machine I want to make a display that can show a trend of the...
1,553
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
131
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
178
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
411
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
160
