Does sort work in AOI?
patjdixon
Nov 2018
Lago Vista, TX
63
I want to sort the public variables in my AOI so that they are ordered when I configured them. It appears Logix does not allow this (greyed out, see attached image). Is there a way to sort the parameters?
Definition shows parameters in the order they will appear on the actual instruction. You can move them up or down.
You need to go to the tags to see the actual implementation values. Then you can sort these.
64
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
63
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
137
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
448
