Download parameters from powerflex40 to pc with 22-comm-e
RodV
May 2012
Chillan
Hey guys
I need to download parameters from a powerflex40 and upload them to another one.
I have a communication card 22-comm-e but I want to connect to it directly from my laptop.
Can anybody give me directions on how can I do this please??
I have installed in my laptop connected components workbench and rslinx classic.
Thanks!!
Do your two Powerflex drives have at least one HIM plug-in module? If so, you can save the User Set from the first one in the HIM module, then move the HIM to the second drive and "Restore From User Set" (copy) to that drive.
You probably mean upload from a drive and download to another...
Do you know the IP Addresses of the 22-COMM-E adapters?
If you do, match your laptop's NIC (or USB/Ethernet adapter) address to the VFDs' subnet (first three octals should match), configure an RSLinx EtherNet/IP driver pointed to the adapter matching the drive's subnet and make sure you could browse to the drives.
Open up CCW, File/New, View, Device Toolbox, pick the VFD type you are going to connect to and bring it into your project tree; double-click (Open) the drive and choose "Upload"; RSLinx RSWho interface will be invoked- drill through the previously configured driver to the drive you wish to upload from; follow the prompts.
For downloading to another VFD use the Parameter File you have just uploaded and the "Download" button pointing to the drive you want to update.
Greetings experts, We have a 'Control Techniques' Unidrive 3405 in an older machine. It appears that the drive parameters are recorded in a .CTD...
750
Hi guys I have a machine with several s210 converters which has the parameters stored on the plc Tia program Has anyone got a step by step...
1,965
Hello, people. I'm trying to download .deh file into Prowirl 200 flowmeter using DeviceCare SFE100, but after connection I've got a message...
1,566
I feel like I should know this but I don't... how can you download all the parameters like maximum frequency etc to a powerflex 4 or 40...
4,975
Hi, everyone: This is my first comment on the forum, i expect to be an active participant, here's one issue that happened in our plant. We...
5,651
