The drive system numbers look idealized to replicate a pretty stout 4-banger. C'mon guys, those of you who read car craft should be able to notice the similarity in the charts...
The torque peak of ~203 foot pounds? With 103 continuous?
The horsepower spike right at the peak of the efficiency?
How does that compare with the Isuzu?
How much weight Gross Vehicle Weight change are you anticipating?
Darn thing just might break traction, but I think not because:
In speed mode, the programmed accel rate prevents wheel hop. You may have to change the accel rate dynamically so it will launch hard, but not try to break free at 60mph on a bumpy road...
Your foot feed is a speed reference, which should not cause spin during suspesion travel, wet surfaces. It, unlike a gas power drive, will still be trying to match the speed based on the controller feedback. If it accurately maintains speed, and suddenly loses torque requirement at the wheel, the wheel should not accelerate much if at all...now if both tires leave the ground, that is different...your open differential and closed speed loop should prove more drivable than the stock engine.
Where can I read the drive manual?
I want one!
Can I ask what a system like that will $et you back?
