Emulating a factory talk view project
If your linx is the free RS Linx Lite, it doesn't support OPC/DDE communications.
I have the rslinx gateway. Also ft view uses rslinx enterprise and not the rslinx classic for communication
Robertmee is correct. You can, and you need to use RS Linx Classic OPC/DDE server with a Topic configuration in order to do this with an emulated backplane. You are able to use FactoryTalk Linx and/or RSLinx Classic in FactoryTalk View.
Here is a rough example on how to accomplish what you are asking.
http://www.plctalk.net/qanda/archive/index.php/t-67064.html
I'm confused. I've never had to use DDE for emulate. I always use an emulator connection under backplane.
No, you're right....for FT. I was thinking back to RSView32 and Wonderware days. WW never had an ABCIP driver for emulate and I don't believe RSView32 supported direct emulate comms, so the only way was via DDE topic in Linx.
I'm fairly beginner when it comes to these sort of things. Previously when I worked on systems, we just used a test bench that we could remotely...
981
Hello everyone! I'm currently programming a safety logic on Studio 5000 Logix Designer V33.00.00 and I wanted to know if there's a way to test...
1,594
Hi, I am intending to emulate a ControlLogix 5571 PLC (on qemu probably). I am looking for relevant information about the CPU architecture, but...
1,885
Hi all, We are trying to make a SoftPLC communicate with a server, but can't seem to make it work. A possible cause is the following error we see...
1,938
Hi All The Fanuc robot that I'm working with has the option of using a floppy disc via it's RS232 port. The discs would be DOS based. But we...
2,515
