Flex I/O 5094 CJC
BAJ
Jan 2006
Maple Grove, MN
201
Has anyone used or have feedback on using the built-in thermistors for Cold-junction Compensation on the 5094-RTB3T* modules? We have a project with a lot of T/Cs and it would be nice to use all 8 inputs for process vs burning one input per module for CJC. The specs indicate the thermistors are accurate +/- 0.5 deg C, which should be close enough for what we are doing, but I'm curious if there are any other issues to be aware of with using the thermistors for CJC.
TIA,
-Brad
Folks, Putting together a system utilizing a Control Logix Gen 8 (5580) PLC w/ the L83e CPU. I'll be connecting to 8 different FLEX-IO drops...
4,108
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
Hi, I'm currently having issued with a PowerFlex 252. It was working fine last week, and suddenly decided to stop working. When I go into...
32
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
82
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
33
