Flying Shear
teritask
May 2007
Michigan
I'm new to PLC's...more of a PC and Labview person for 20 years...Question to you pros out there...We're building a flying shear machine (I know, basically reinventing the wheel). The hardware chosen (and purchased) is an AB 1769-L32E. We are not controlling the pipe feeder, just synchronizing with it. My question of the day is...did we blow it with the hardware? Will I be able to use the motion instructions to control my accelerator? We're not using SERCOS...the drive is controlled with +/- 10V analog output (1769-OF2). Kind of worried that this isn't going to work. Any thoughts?
Thanks in advance,
Teri
Well, the bad news is you've got a PLC without the motion capabilies native to the CLX line.
It would be much easier to synch the shear with a L43 processor.
You are going to be hard pressed to do this in the L43. The only motion module AB makes for the L43 is a SERCOS module (as far as I can tell). You could try to do it all in the L35E plc through standard I/O. Without knowing your system I don't know how reasonable that is.
Since you already plan on going with the L32E I suggest you look here:
http://www.deltacompsys.com/products/motion/rmc70/cpu75e.php
You can connect from the PLC to the RMC75 via Ethernet I/P and let the motion controller take care of the motion.
Keith
Hi All, I Have a question, I am very thank full to you if help me, I designed a flying shear controller based on fpga and microcontroller, but...
20
4,424
I'm working on a flying shear application consisting of two kinetix 350 drives. I need to find a way to connect the encoder connected to the...
2,810
Hi All, I have been asked to look at a flying shear tube mill and improve on its accuracy currently running at up to +/- 3mm and needs to get down...
50
19,694
Here is a nice flying shear application. This type of project is often asked about here...
3,443
Hi.. I have flying shear application using rotary knife. The line speed is 100 FPM and rotary knife using Vector motor with Inverter for speed...
6,474
