FTV ME - Displays and maintained push bouton
jl_h2o
Mar 2016
Victoriaville, QC
27
Hi guys,
So, I'm looking a way to display a menu when a bouton is pressed and close it when the same bouton is pressed again.
So, with a maintained bouton I changed a bit. Then display the menu with a event... wait... there's no event with ME. šŸ™ƒ
Alright, with a macro then! Oh... Yeah... Macro have limited function in ME.o_O
Seriously RA?šŸ™ƒ
Anyway, have you, guys, an idea how to do this?
Rightclick on menu > Animation > Visibility > As tag/expression, just put in the tag/bit you're changing with the button.
That's what I've done for now. But it a little pain in the a"$ to do since you need to change the visibility of every item.
I'm looking a way to do it with a whole display?
The hard way.
Go To Display button which is visible when not on that Display.
Go Back To Display which is visible ONLY on that Display.
Best I can do with my limited knowledge...
Finally, I've adopted and another option.
I use a Go To Display Button to display a page and added a "X" to exit that same page.
Still, I'm a little disapointed by ME from FTV....
Thanks for your help Jeebs
I would use On Top displays for your menus.
You could number the On Top displays, then use a momentary push button to set a memory tag and open that menu display => writes to global connection Remote Display Number.
Use a second momentary push button to close that menu display => writes to global connection Close an On Top Display.
That would give you your click once to open, click again to close.
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
144
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
114
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
158
Hi to all, Does TIA portal support creating reusable pop-up display as FTV has it implemented? Something like on link below. Thanks in advance.
552
Hi all, I have a question about the communication from the FTV and the PLC for different machine I use. Most of these use a SLC5/04 PLC and...
317
