FTV SE Not Displaying UINT Properly
AMarks95
Jul 2018
South Dakota
224
I have a UDT with multiple elements that all show on the display perfectly using direct reference.
For example I have the following instance on a PLC with shortcut "[PLC]"
Customer_Data[0].Name = 'Dave' (STRING)
Customer_Data[0].ID = 1234 (DINT)
Customer_Data[0].Location = 0 (BOOL)
Customer_Data[0].Type = 3 (UINT)
When I reference the customer information for display in a text object like so:
{[PLC]Customer_Data[0].Name}
{[PLC]Customer_Data[0].ID}
{[PLC]Customer_Data[0].Location}
{[PLC]Customer_Data[0].Type}
Name, ID, and Location all show up correctly. However, I get an error message that "{[PLC]Customer_Data[0].Type}" is unresolved on the device.
Has anybody else run into this?
I generally found that FTV doens't like USINT, UINT, and UDINT.
I came across the same thing with another program where I thought I'd use a UINT and FTV didn't even like using the bit level of the UINT.
If you dont really need the UINT i would consider changing it to a INT or DINT, or moving the UINT into a different INT of DINT the HMI would display.
This does not surprise me, UINT's were added relatively recently and are only supported in the 5380/5580 controller platforms.
It appears, that support for these data types for FactoryTalk was added in v12 and FTSP 6.20. So you may have to upgrade and/or patch to be able to properly use them in FTV. KB: BF27545 discusses this.
Hi Guys! What are the possible causes of Multistate Indicators displaying 'error' messages when test-running application in Factory Talk View ME
1,974
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
130
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
101
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
135
Hi to all, Does TIA portal support creating reusable pop-up display as FTV has it implemented? Something like on link below. Thanks in advance.
531
