GE Fanuc 18I Controller to Kepware
dans
Oct 2008
Houston,Tex
I have been trying for some time to connect an read spindle load off a Johnford Lathe - I have installed the required(according to GE FANUC) communications board - Kepware does see the board but I can't get any information on the code to read spindle load and post to an OPC Server - Does anyone have any ideas on how to do this??
KEPWare Note: This driver uses and requires either the Focas1 or the Focas 2 interface libraries available from GE Fanuc for full online operation. The driver allows development of application without the library.
Probably, you don't have them.
Joern
Kepware Support is free. Call them to get further help. Also make sure you have the latest server version v4.300.449.0-u. Changes were made to the drivers recently.
Hello everyone, I am new to the forum and new to PLC's and was wondering if anyone in here is familiar with FANUC and or TOYOPUC Plc's?
1,709
Not sure if this is the right place for this question but.....Ihave a GE FANUC 18i-TB control on a Hardinge Elite 27MS.My question is in regards...
3,250
Hello I am trying to find out what parameter I need to enable use of the real time clock for macro programming. The machine is a Muratec MS6 Lathe...
25
15,253
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
38
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
125
