Sure, but in this case I think it is luck.CharlesM said:It wasn't luck because they knew the 128 limit when they started. There is an old saying here, "I would rather be lucky than good" I tend to think that Peter's company is both.
Good tidbit of info there ! Didnt know that.Nick B said:Any CPU 315 and bigger (V2.5+) can have it's process image stretched.
Nick B said:Any CPU 315 and bigger (V2.5+) can have it's process image stretched. I prefer this method. It's also the way PCS7 does it. They stretch the image and drop everything into a huge IW/QW area.
Nick
Isn't this the case with pretty much all CPUs?S7Guy said:One thing to consider when stretching the process image (I've done it in the past on the 400s) is that it does take longer to update the image. That said, the time increase may be inconsequential, but I can't say for sure. I seem to remember an application note from years ago that if the PI was shrunken and all IO was made as contiguous as possible, then the image update time would be quicker.
Some day I am going to have to sit down with a processor and scope and run some tests of my own.
bkottaras said:Isn't this the case with pretty much all CPUs?
ControlLogix will do the same. They recommend using the same technique to keep scan times down and have better update and consistancy. I believe this is true for all image tables regardless of manufacturer.
Thinking about it. Data is data and fills locations.It must be read somehow which will take time.S7Guy said:Yes, it probably is. I just don't know what the real implications are.
For instance, let's say that "out of the box", my CPU use 0-511 for the process image and 512+ for the peripheral image. If I am only using bytes 0-19 of the process image, do I gain anything by shrinking it to 20 bytes and have my peripheral area start at byte 20? I'm not sure.
This thread has made me think about our interface. I know we have magic click points but we also have entries in the main menu so one can find what they need from the main menu or by right clicking on the project tree.I remember using Protool a while ago, and I was supposed to know to <ctrl>+rightmouse click on a certain screen 'repaired' unused tags.
The old S7 had that problem, not the new ones. Our RMC100 was one of the first Profibus DP slaves to be ceritified in north america. We were the first to pass certification the first time. The Profibus test center made us limit the number of I/O registers initially to 16 words in and 16 words out. That meant that we had only two registers in and two registers out per axis. ( we support 8 axes ). The interface was easy but it required that parameter be hand shaked through the Profibus I/O on register per axis at a time. This would take about 700 milliseconds. In most cases this was not a problem. Then Siemens came out with the CP342-5. This allow use to have 3 data areas. One 32 register are for status and two 64 word areas for sending messages back an forth. The CP 342-5 had data consistency up to the Profibus DP limits of 128 bytes or 64 words. Our customers liked the new mode but not the extra price and performance of the CP 342-5. The CP-342-5 required yet another two functions DP-SEND and DP-RECV. TThe Siemens plastic group in the US used our motion controller until Siemens came out with their own product. They liked to use our Message Mode on the RMC100 which is a 16 bit integer controller. At first they used the CP-342-5 but it raised the cost. Transferring data across the back plane isn't fast with a S7 either. Then Siemens came out with a new version of the S7 that allowed message mode from the DP ports on the S7 itself. This happened about three years ago. The DP ports on the S7 allow faster transfers between the Profibus and the CPU.C14/SFC15.
edit: The 128 bytes mentioned is the maximum consistent data for Profibus. The 32 bytes I mention is a limitation with S7-300:
As CharlesM said, luck has nothing to do with this. We made our Profibus DP interface work the best we could within the Profibus DP limitations. If I could I would allow more registers in and out. We can actually. The problem is that if you had a project with 5 RMCs the Profibus DP I/O map gets used up fairly quickly.You are lucky because the 128 bytes in each direction exactly matches your requirement for 32 doublewords (REALs).
See CharlesM's project above. His I/O is consistent and not within the normal process image. As I said above, this capability has existed for a few years now.If the location is outside the normal process image, you get max 32 bytes consistent data, and you have to use SFC14/SFC15.
What will it take to convince you. We knew about the limitations. You are looking a this from a single point of view, Siemens. SST and other PC Profibus DP master had the ability to send 128 byte of consistent data long before Siemens did. Even the TI505 could send 128 bytes of consisten data before the S7 could. Stranger yet. A PLC5 with a SST card was a MUCH better master than the S7 for many years. The SST card in the PLC5 could do the 128 byte consistent transfers and the data would automagically just show up in a N file or be read from a N file. No SFC14 or SFC15 required!!!! Siemens has just caught up.JesperMP said:Sure, but in this case I think it is luck.
See this threadSome day I am going to have to sit down with a processor and scope and run some tests of my own.
I don't think that keeping the PLC image table compacted will any difference. Each slave must be updated with a separate call or data transfer. The number of transfers or packets will have the most affect on the I/O update time.
I can't answer for the S7. In our case the image table is small and the I/O is allocated in a contiguous manner so there are no gaps. The digital and analog I/O processing goes extremely quickly and is an insignificant part of the scan time. All the I/O can be read in less than a microsecond. The Profibus and Ethernet I/O take MUCH more time.S7Guy said:These are two different issues though. Ignoring PB for a moment, I wonder if there is any difference in the real scan time if I am only using local IO (or for that matter, no IO at all) and I make the image very small. I know that in the old S5, it was recommended to keep the IO contiguous, but then again the S7 family is much, much faster (at least with the 400s and some 300s).
I would need to look. All our early tests were done with a SST Profibus DP master that was PC based. The SST Profibus DP masters are very fast because they have a CPU dedicated to just processing Profibus DP data. SST claimed they could update 6000 i/o bits per millisecond. At 12 MB/s 100% efficiency would be 12000 bits per second. That is an efficiency of 50% which is very high relative to other buses. From what I saw I believe it. The S7s scan time does not stress the Profibus DP. I saw no need to evaluate it the S7 because it is relatively slow. We tested the SST Profibus Master and one RMC. The SST card would do 3 data exchanges per millisecond. The RMC100 could only update 1024 times a second or every 976 microsecond. Obviously the data was only updated every third data exchange.When PB slaves are thrown into the mix, the process image is probably irrelevant. During your tests, did you find much difference between your results and what Siemens calculates in the hardware configuration?
No problem. I figured you forgot about what I do .... again.JesperMP said:My remark about luck was Obviously too snooty. Sorry about that.
That still may apply to some of the smaller CPUs. I didn't think my customer's S7-313=2DP would support 32x32 in and 32x32 out but it did. I am using a S7315-2DP. I assure you that my project has 32 32 bit register in and 32 32 bit registers out. My project is similar to CharlesM's example in the previous posts.I dont have the actual experience with large blocks of data having to be consistent. I just read the manuals and draw my conclusions from them. In the latest STEP7 v5.4 it it still mentions that it is max 32 Bytes for S7-300.
But another place it also say that one shall check what each CPU supports. So I have attempted to locate that piece of information for the 313C-2DP. I have checked ALL the manuals for S7-300, and ALL FAQs for "data consistency" but have failed in finding it. All I found was another reference to that the limit is 32 bytes.
It was a joint effort between me and two engineers of the Siemens plastic group. Originally we used SFC14 and SFC15. This was back when the S7 supported the limited number of registers 16x16 in and 16x16 out. This was very limiting. The graph data could not be read from our controller fast enough because of the limited number of registers. A 'bigger pipe' was needed to get the data in and out faster. Siemens developed a CP-342-5 that allowed 2 input blocks ( 32x16 and 64x16 ) and one output block ( 64x16 ). The CP 342-5 used the DP-SEND and DP-RECV instead of the SFC14 ( DPRD-DAT ) and SFC15 (DPWR-DAT). Around 2003 or 2004 the new S7s were released that supported the message mode. Then the SFC14 and SFC15 were used again. We never used the peripheral I/O below 256. We always used the location assigned by the hardware configuration which is at 256 or higher.Peter, did you or did your customer do the S7 programming back then ? I am asking because either they (or you) used the process image method, or the manuals are wrong.
