Help with safety programming on LogixDesigner
royalmaster
Jan 2020
Brazil
20
Hello everyone!
So I'm currently using the Studio 5000 Logix Designer V33.00.01 and I need to program the following safety modules:
5094-IB16S
5094-OB16S
5094-OW4IS
I wanted to know if you guys know any manual or even a tutorial on how to program them (the modules are already in the I/O configuration).
Thanks a lot for your help!
Best regards
There is a ton of information on safety programming in the technotes. The way safety programs are written by rockwell have changed significantly over the years. Try the newest ones first.
ROYAL
Are you asking specifically about how to configure the modules?
It sounds as though you are asking how to write the safety program.
That is a totally separate thing...:)
ROYAL
I meant more on how to write the safety program. sorry if I wasn't clear, english is not my first language. Thanks for the heads up
thank geoff
I've been reading these technotes this morning and trying to figure this stuff out
There is a lot to consider when writing safety logic:
What Category of Safety are you trying to achieve? That not only dictates the type of code required, but the amount of I/O and field devices necessary to achieve the Category rating. A brief synopsis of Categories: https://www.automation.com/en-us/articles/2011-1/safety-related-control-systems
Do you have the necessary I/O and devices to achieve the required Category for your process?
Once you are able to define the above, then you can start looking at the various Safety Instructions and how they are used in conjunction with Safety Categories. Most of my installs use E-STOP, DCS and CROUT instructions.
Safety code is not for the inexperienced as loss of life, limb and machinery can occur by not programming adequately. A safety system is only as strong as its weakest link.
thanks for the reply robert
I'm honestly new in safety programming so I'm kinda lost on where to start. I'll read the content you sent, thanks for the help.
Good evening, I'm primarily a Siemens user, but I have an incoming project where I need to use Allen Bradley everything. So far I know that the...
2,646
Hello again! I have a new piece of equipment and there is a SafeZone Safety laser attached to both sides of the traversal unit (442L-SFZNMN A)...
749
First off I know this can get very involved so I will attempt to respond with whatever questions you guys have. I know this is a very loaded...
2,416
So I have been trying to give myself a crash course is safety circuit design in the last few days. I put together these examples and I wanted to...
8,179
Hi, Guys: we have safety relay 440R-G23216 with reset function, in our application we jumped Y1 and Y2, the reset button one wire connects to S33...
3,298
