Help with Siemens 440 drive analog out...
Shiro485
Apr 2013
North Haven CT
103
Hey all,
I am having an issue getting a proper analog output out of a Siemens MicroMaster 440.
Im looking to scale a 4-20ma out into a compactlogix plc for an actual running hertz representation.
It is reading values however the two different parameter settings that allow me to see values one floats at or around 7-8 ma regardless of speed drive and the other ramps up from .10 to .67. I have the scaling settings on the drive set for 4-20ma.
Can anyone offer any assistance?
Much Appreciated.....
Thanks.
Brian
http://www.scribd.com/doc/89822989/Micro-Master-440-Parameter-List
For a parameter list.
Hi!
Have you checked the AO -parameter P0771? You can see which signal you want to output, and how it is (mis)treated before it gets to the output terminals.
Kalle
P0771 defines the function for AO, it does not display the value. Display value of analog output is in r0774
As for dip switches, i think he done that as he said that he already scaled the output.... :unsure:
maybe the scaling is the problem...
try posting a setup for parametrs regarding the analog output...
Hello good day : micromaster have a 440 installed on a machine, when I push button start machine micromaster machine works well, up to speed and...
2,196
Hi All, Today we had a drive die on us. There was no backup but we have a duplicate drive in service. Can't upload via AOP or starter but Siemens...
11,461
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
379
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
962
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
337
