high speed counters
jose7771
Jan 2005
42
hi 2 all,
i wanted to know what is meant by high speed counters
and what r its application in automation and how it is implemented
regards
jose
Quite simply, to keep track of things that happen faster than normal PLC scan rates. High Speed Counter modules can process signals independently of the PLC. Many of them have their own outputs. You can think of one as a high speed PLC embedded in a larger PLC.
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,725
Hi everybody, I registered to this forum because I simply can't figure it out, how to properly set HSC in Proficy Machine Edition for my Versamax...
17
3,777
Hi, im using the built in high speed counter of omron cj1m cpu22. I will be connecting a rotary encoder to the high speed counter. The rotary...
2,496
Heya everyone thanks for reading im stuck with a project im doing at work and cant find the problem :( I have an mitsubishi FX3U system connected...
3,158
Hello, For a year, I had high speed counters working flawlessly. Today, they were still working. Now all of a sudden, nothing. All other I/O...
50
15,923
