Intouch 8 and SLC 503
Lost_Man
Apr 2005
22
Hello
I am wondering if there is a driver or another program other than Rslinx to read data from SLC503 to Intouch 8.
Alot of threads here suggest buying RSlinx OEM or professional, but I dont have the resources for that. I am learning on my own and trying to get into SCADA. The price range for RSlinx is beyond on what I can afford.
So please if you know of a solution that wont cost much (less than $100) let me know know
If the serial port is free, you can use the free Wondeware Serial/DF1 driver. If you want the DH485, you will need a 3rd party IO server.
Lost Man,
I have seen "used" copies of RSLinx on E-Bay for less than $100. Right now (3/25/06) there is a used copy of RSLogix 500 with master key disk and RSLinx Professional for $265.
I have downloaded and installed Matrikon opc for Allen Bradley, when I tried to run it, it gave me an error about program ID.
"Could not find ProgID 'PSTCFGMatrikon.OPC.AllenBradley'!
When I installed I just kept the dafault ID "Matrikon.OPC.AllenBradley" I also tried "Matrikon.OPC.AllenBradley.1"
Hello! I have 4 SLC503 processors and a PC, running InTouch. Also I have 5 1761-NET-AIC modules and 5 1761-CBL-AP00 cables to connect all this...
4,719
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
37
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
144
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
136
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
178
