OK, sometimes you have to stop thinking like a PLC programmer and instead go back to first principles. If I had a 0-10 range with a value of 2. what would be the inverse...... 8. How do you get there.... 10 minus 2. So the simple command is a subtraction. You might have to get a bit more complicated if the range doesn't start at zero.
