Inverse signal
kevbloke
Jul 2004
Kent uk
81
Hi all. I have had a pressure sensor die and the only one i can find is working back to front.
Can anyone tell me what i can do in step7 to inverse the signal from PIW370 in my program please. Is there a simple command i can put in?
OK, sometimes you have to stop thinking like a PLC programmer and instead go back to first principles. If I had a 0-10 range with a value of 2. what would be the inverse...... 8. How do you get there.... 10 minus 2. So the simple command is a subtraction. You might have to get a bit more complicated if the range doesn't start at zero.
Had a bit more time to think and if you want a more complex solution then use a 'Scaling' routine. Disadvantage it takes longer to process, Advantage it takes care of any offsets within the routine.
Hi Guys, I'm Using Delta DVP-ES200R On a project, I wanna Establish an Inverse Relationship Between Two Variables (Speed, Motor AMPS)... I Have...
2,013
my application is a respooler. A spool on the takeup spins at constant speed, the payoff(5hp motor) is PID controlled. Currently using a Yaskawa...
3,305
Hello everyone! I have question regarding simatic 300 plc and inverse kinematics. I have to program software for 4-axis SCARA manipulator. I'm...
3,182
I am hoping someone can explain, well actually point me in the correct direction to be able to do the math on an inverse slope. This is was I...
19
6,121
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
246
