Kinetix5300 with Compactlogix L33ERM
JDel
May 2022
Guatemala
Hello guys!
I need some help here. I configured my kinetix 5300 drivers with a compactlogix for the first time and they worked. However, when i powered them up again the next day, the drivers' screen showed -00- and the axis group in the PLC showed all the axis as disconnected. To fix this, I did the following:
1. Powering everything off, then on again
*. Downloading the program twice
With this, i made the drivers work again.
The issue is that I shouldn't have to download the program again in order to make the drivers work after each power off.
I don't know what to do or test :confused:
If somebody has any idea I will be grateful.
Welcome to the PLCTalk forum community !
Double-check your IP configuration on the PowerFlex and the controller, to be certain you don't accidentally have it set for BOOTP/DHCP.
That "00" does mean the drive is waiting for a connection from the controller. The controller status message indicating it can't connect to the drive really means that too.
Do the ordinary troubleshooting: PING each device's IP address, and type it into a Web browser to see the embedded webpage, and browse them with RSLinx.
If this is a new installation, don't discount the possibility of a bad switch or cable on the Ethernet installation.
120
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
165
327
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
194
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
136
