Logix Designer: "New Module" grayed out
MoraleC2
Jan 2016
East Coast
23
I am unable to add or discover modules in Logix Designer, V28.02, when trying to do so under the PointIO of a 1734-AENT. I can add modules one level above - in this case, on the ethernet network - but I cannot add anything to a rack. This happens on several different projects, two different VMs, and different versions of Logix Designer.
Has anyone else experienced?
Are you trying to do it online? I'm pretty sure that you can never add point I/O online.
No, I am not. Even if I add a brand new chassis, it will not let me add anything to it.
Did you change the chassis size of the new chassis before trying to add modules? If not, then it will default to 1 and of course you will be unable to add modules to it.
We can't tell from the graphic you posted how many slots are available. It looks like there are 13 slots defined, but we can't tell how many are already in use. You won't be able to add to the Point I/O chassis if it is full unless you first define additional slots.
Also, when you create a new Point I/O chassis, the size defaults to just 1 slot which would prevent you from adding anything as well.
The Discover feature only ever works online. When offline we have to manually add each module. I can't think of any other reason it would not allow you to add Point I/O modules. Unless maybe those module profiles aren't installed. Just a WAG there though.
OG
EDIT: plvlce got his comment in as I was typing mine. Faster typist I guess :)
Considering the difference in post times…
As OG stated, you cannot discover while offline.
If you are attempting to install new modules, you must increase the chassis size before you can add anything to the configuration.* If you created a new chassis but did not increase its size, the fact you have the same issue with that new chassis is further support for the theory this is the cause.
*unless the chassis was already oversized for the physically installed modules.
Lol...I started my reply before your comment posted. But I got distracted with work and then launched a VM to verify my thoughts before I posted. By that time, you had already replied. I didn't realize that much time had passed though.
OG
Hi Folks, I have 1756-L81E (CPU) (Firmware: 33.012) 1756-EN2TR (Ethernet Module) (Firmware: 11.002) 1756-RM2 (Redundancy Module) (Firmware...
1,487
Hello everyone! Do you guys know if there is way to configure the module 5094-IB16S on Logix Designer v33.00.01 so its outputs become available...
1,753
I'm running into an error I haven't seen before with regards to adding a Prosoft 1756-MVI56E-MCM card into a rack of an offline project. When I...
2,438
Hi PLC programmers, I got a problem regarding my installation of Logix Designer/Logix5K. Here's the situation... a) Initially installed Studio...
24
44,232
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
251
