Micro870 CCW: Signal stops before coil, coil does not get energized
pml_28
Apr 2020
Brazil
Hi all. This is my first time working with the CCW software, and I'm using the CCW developer edition version 21. The PLC is a Micro870.
Basically, my coils are not being energized in any routine (I can see the red signal going to the coil).
Some tests are already done:
- PLC with the switch in the RUN position;
- The coils are being used in one place in the program;
- The program has no Jumpers or any instructions in this category;
- I thought I should initialize the routines. But it seems that this is not necessary in CCW.
Any suggestions?
Are you sure of the condition of the output? I had a Micro820 that was turning on a 120VAC signal to a solenoid that fused open the relay.
If you force the output high in CCW, does the output energize?
I'm adding as an attachment a screenshot of what is happening. The problem happens with physical outputs or even simple variables (memory only).
view
https://drive.google.com/file/d/1ime4B9uUoKk0UgYX4cusIg6VQE5or7ZC/view?usp=share_link
Are you sure that rung (routine?) is being executed? put an unconditional [+ a_real 1.0 a_real] before that rung, and see if it increments or not.
Cross reference HSC9026 and look at what changes that. It could be turned off before this rung and turned on after this rung, and display as true while actually false at this rung in the program scan.
Hello everyone, I am trying to send/receive Modbus messages between two Micro870 PLCs using RS485 and 2x2080-SERIALISOL plug-in modules. PLC1 -...
1,427
Hi, I'm using a Micro870 - 2080-L70E-24QBBN and does anyone know the difference between a 2080-IF4 and a 2085-IF4 other than how they connect...
637
I am working on a project where an AB Guardmaster 440C is the logic solver for some SIL-rated interlocks. I need to be able to send reset bits...
749
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
64
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
243
