MicroLogix 1400--write to (adjust) real time clock
Skidood
Oct 2016
Ontario
215
Hi all
I thought I had this working but upon doing a checkup a few months after the machine was commissioned, I found that adjusting the RTC via the HMI results in a controller fault. I am simply copying an integer representing (for example) the minute of the day and sending it to the RTC. See the image I attached.. My understanding was the the Copy Word instruction was the only way to do it. I don't know what to put in as the length..is 1 OK? Again, I could have sworn this was working fine during the program debugging phase . Can anyone comment?
By the way, I do know that invalid values (eg 27 for the month) will fault the processor....I have checked for this possibility, all is OK.
Try using a one shot on the push of the button.
What currently happens when the button is held during the seconds increment from 59 to 0?
May not be related to your issue, but i seem to remember that if i didn't initially set the RTC (using the RSLogix environment) it would fault the controller. Once it was set once and had valid data, it seemed i could write to the RTC registers as per your code without issue.
Rob
Hello i have two systems workering together with a Micrologix 1000, where their are communication between them with a serial cable. Now i have...
2,418
I have been using dotnet and OPC servers (NI and Kepware) to communicate with Allen Bradley Micrologix 1400 PLC on different environmental...
5,796
36
99
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
224
