OMRON Network Number Problem
ctor
Nov 2019
Spain
I am trying to connect a new CJ2M-CPU31 to a used NS12-TS01B-V2 (it seems to be restored to default). I want to connect that using Ethernet.
In the Cx-Designer I have set the following for the NS ethernet Port:
- Ethernet: Enable
- Net number: 1
- Node number: 5
- UDP Port: 9600
- IP address: 192.168.140.5 // 255.255.255.0 // 0.0.0.0 // 0.0.0.0
And the following for the host:
- Name: CPU_A
- Type: SYSMAC-CJ2
- Protocol: Ethernet/IP
- IP Address: 192.168.140.10
In the Cx-Programmer I have set the same IP address for the PLC from the I/O table configuration.
However, they are not connecting. After some seconds the HMI shows a Time-out Error. I am used to works with this kind of HMI, I think the problem is in the PLC because this is my first time working with a new, out of the box, PLC.
I have tried to comunicate them using the "Com. Test" tool from the System Menus of the HMI; however, I didnt get it.
I think the problem is than the integrated ethernet port of the PLC is not in the Net Number 1. I have tried to set it using Cx-Integrator. I have clicked in "Create routing tables" -> "Insert SIO CPU unit" for the Unit250(Integrated Ethernet Port) -> Local network number = 1 -> Transfer to PLC.
Nevertheles, the windows "Online Connection Info" is allways showing Net(-) instead of Net(1):
"Ethetnet [CJ2M-EIP21] Net(-), Node (10), Unit (0)"
I have checked the Cx-Integrator Manual and says in this case it is only neccessary to "Connect", but I have tried it, waited for the 254 nodes, and... it doesn't work!!
I don't know what to do!
Thank you.
Where have I to do that??
I have already enable and set the ethernet port and I have select Ethernet/IP for the communications with the host...
Could you check it in the first post?
Thank you very much
Hi, I am facing an error inside Omron Network Configurator. I have 2 PLC communicate each other using ethernet cable, send signal using Network...
142
All, I'll confess that I'm not an experienced PLC programmer. I'm setting up an Ethernet/IP network using a EIP21 Ethernet/IP module in a rack...
1,598
Good Morning All, We am currently in the middle of migrating my control system servers over to our new virtual server set up. However this as...
2,162
Hey guys, I'm trying to get some non-safe Input from a Mits Q-series PLC via Dnet to a NE1A. The NE1A is the master on the network and I'm...
2,736
Hey Guys, I'm trying to program a new Omron safety PLC, NE1A. I was given a running program by the client and he said he wants it just like the...
1,983
