nickegeson
Anyone know if the Codesys based Schneider PacDrive LMC Pro 2 has an built in OPC UA server? As far as I understand it should but I can´t seem to figure how to connect to it. Optional I need to use an external OPC server with Codesys driver, which works. Anyone has any experience on this? I tried to follow some tutorials for Codesys, and it looks like if the symbol configuration is set correctly you should be able to read it from a client, but with the Pacdrive I don´t succeed. Is there a certain port number to be used for this purpose? Or where can I find the setting?
