Panel PC with second Monitor - Recomendation
rguimond
Jul 2009
Escuminac
666
I'm looking for a suitable industrial panel PC to replace two circular chart recorders. The PC will run a data logging / display program. The panel PC will display real-time data for one process, and the second monitor will display data for the second process. PC and second monitor will be within 3' of each other.
There seems to be any number of panel PC manufacturers out there, so I was hoping someone on this forum could recommend one or two.
Minimum Specifications
Windows 7 (XP would also be acceptable)
on-board LAN
External VGA port
15"
NEMA4 rating
Trim on panel PC and second monitor should match.
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
44
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
92
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
229
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
420
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
96
