Panel with buzzer
orense
Apr 2006
Norway
196
Hello,
Does anybody know if there are any panels with builtin buzzer.
We are planning to use them in cabins on ship, so if any alarm from the control rooms, then we can notify the crew without using a seperate cable and buzzer.....??
Thanks.
brg
Andreas
By panel I assume you mean an HMI.
Many models of HMI [For example Omron NS] have a built-in buzzer that can be turned ON and OFF with a control flag accessible from a PLC.
Though whether these would be loud enough to hear in ship is questionable.
I know the Automation Direct C-more has both an internal piezoelectric buzzer (not very loud) as well as a line-level audio output, but then you would have to connect an amplified speaker to it.
my 2c
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
58
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
106
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
230
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
421
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
99
