PLC5/11 to new Foxboro (FBM230) - 1785-KE?
Oct 2009
Warrington
Hi there, first post
I'm wanting to interface to a couple of old PLC5/11s to a new Foxboro system. At the moment they are connected to a Foxboro node using the AB-station bolt on to the DNBI cards. I now need to communicate to the FBM230 serial or FBM232 ethernet modules.
COMM0 on the 5/11s is being used for other comms so i can't connect direct to that as i'd wish (FBM230 using DF1 protocol direct) and i don't really want to use the big ugly grey 1770-KF2s and jump in on the existing DH+ network (which again is doing other stuff) so i'm looking for other ideas
One thing i came across is the 1785-KE which can communicate with the FBM230 on the serial connector, but how much work is involved in installing this module in the PLC5? Is it plug & play, will my original read requests work or is there data mapping involved, firmware upgrades etc etc? is it even compatible?
Other options are maybe one of the Prosoft modules MVI71-DFCM, MVI71-MCM, MVI71-DFNT, MVI71-MNET perhaps?
Finally is there (fingers crossed) a way to reuse the AB-Station? The DNBI connects via the two larger serial connectors but there is an unused COMM0, 9 pin type. Does this by any chance work with the DF1 protocol so i don't even need any new hardware!? Information about the AB-station seems hard to come by, i've got foxdoc B0193MK and AB 1785-2.37 but neither of them explain what COMM0 is for
Any advice greatfully received
Martin
One of our clients has a PLC 5/20 communicating to Foxboro DCS over Modbus. There is a Prosoft Modbus Communication module in the PLC5 chassis...
4,810
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
191
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
405
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
572
