PLC5/30 not seen by RSLYNX
jb1
Mar 2009
Illinois
Good morning..I'm trying to test a PLC5/30 processor using RS-LYNX...but the RSLYNX software does not communicate / find the processor. The processor does not have any program loaded into it, since it's been sitting around for quite some time. Any ideas....? I tried a known "good" processor that does have a program loaded, and the software has no problem "seeing" / "communicating" with it....
Give us some more details... How are you trying to comm with the PLC5/30? DH+, serial,...?? Comm parameters?
See link below for RSLinx serial set up.
You might try defaulting the processor by removing the battery then reconnect it.
Also check the processors dip switch make sure its set for RS232. ( see pic below
  • rslinx_setup_serial.pdf
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
167
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
386
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
543
Hello all, I am seeing this behaviour where an integer file (N46:33), has an integer in binary (11110) which is 30 in decimal. I did a...
532
