PLC5 HotBackup with Flex IO Configuration
Joydip
Guest
J
I am using PLC5/40C as Hot Backup in ControlNet.I used 1794 ACNR15/C ( Flex Module) as a controlNet adapter to connect I/Os.In RSNetworx for controlNet all the I/Os and the 1794 ACNR15/C adapter were added to the Scanlist of Primary and Secondary PLC. I inserted a connection against 1794 ACNR15/C as Discrete Redundant Owner which would establish connection with all Flex digital modules in Rack Optimization format.Now I wnat to add Flex Analog input and output modules to the primary and secondary by inserting connection from Scanlist configuration ( direct connection format ). But the option
" INSERT CONNECTION" is not enabled for analog modules. How do I configure connection of Flex analog modules to primary and secondary PLC5/C ? Is it related to Firmware of the Flex Adapter ?
Hope somebody can help me.
Hello Configuration situation: Our control system have several type of plcs, (6) plc5/40, (4) slc500 5/04 and (4) controllogix, also (4)...
1,884
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
158
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
378
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
529
