Power Flex 70
the eye
Jul 2009
El Salvador
Hello everyone, Recently one of our AB PowerFlex 70 has failed and we need to know if is possible energize the device by 24 V to only see the control system, leaving the engine locked whit a jumper or somthing.
Hope you guys can give some advice ... Thank in advance
No. The PowerFlex 70 does not have a control power-only input that will only energize the control board.
Some PowerFlex 700 drives can be powered this way (see the User Manual for details), but not the PowerFlex 70 drives.
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
Hi all. Would anyone happen to have the Modbus register datasheet for the Honeywell/EnergyICT EIMFlex Modular Meter v1.11 We've 40 of these that...
69
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
128
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
191
i have a flashing yellow sts light. "Stop Asserted" message on one of my PF 753"s, but no bits set in parameter 961. The safety circuit tests...
209
