PowerFlex 525 Auto MDIX ENET Port Capability
aiki202
Aug 2007
Pennsylvania
178
Does anyone know if the PowerFlex 525 embedded EtherNet/IP network adapter port offers 'Auto MDIX' (aka auto crossover aka auto switching) capability?
I know I can connect directly to drive with laptop with a standard patch cable... but is it the laptop or drive providing this function?
The laptop... that is what I would think as well. Although the laptop certainly has this capability I was curious about the drive side. I reached out to RA Tech Support and according to them the PF525 drive does has Auto MDIX capability as well (so does the PF750 series drives).
Just as a test I connected two PF525 drives to each other via the embedded ENET ports. Each has a unique assignment on the same subnet. I used a standard straight through patch cable... according to the drives ENET LEDs and parameter F683 there is an active connection between the devices (although no Tx or Rx... nothing telling them to talk to each other... but they can see each other)... seems to confirm what tech support is telling me as well.
I am trying to wire a 525 vfd for a Hand/Off/Auto setup. Hand is a manuel start cmd (T 11 to T 2). Auto will be over ethernet. I am not for sure...
4,390
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
88
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
86
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
259
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
267
