PowerFlex 525 Unable to Completely Stop Motor
So were you in V/Hz mode prior to that?
Did you perform an Autotune?
Correct, we were in V/Hz mode prior. He put it in SVC mode and immediately the symptom went away. Unfortunately some other issues in my plant needed my attention so I'm not sure if an Autotune was performed post change.
My 2 cents.
I would implement a discrete start/stop signal or via comms to the drive and not rely strictly on the 4-20ma signal. While I do recognize the "sleep/wake" mode will deal with the lack of resolution effecting the low signal level (4mA) if you get a surge on the analog signal you could get a jump in the drive. If the discrete input is off then it won't matter what the analog signal is at, the drive won't start. Having said that I'm not a "drives" expert so I don't know what standard practice is but I use drives a lot in demo displays and if I had to deploy one in an application I would feel much more comfortable having a digital signal control the start/stop with the analog controlling the speed.
Again, just my two cents.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
238
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
248
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
485
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
242
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
305
