programming Galil controller
khewes
May 2016
New Hampshire
123
Good morning everyone,
I'm working on programming a galil controller using galil tools and a panel pc. I want to interface the HMI with the galil controller using windows form in visual basic format. The form connects to the controller but the controller does not respond to commands when a button is pressed. can anyone see any errors in my code? I added a galil reference to the form. The code is below, and attached is the project.
Public Class Form1
WithEvents g As New Galil.Galil
Private Sub Form1_load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
g.address = "10.50.200.231"
Me.Text = g.connection
End Sub
'when button1 is clicked perform galil command
Private Sub button1_Click() Handles Button1.Click
'SET INPUT 1 HIGH ALL OTHER INPUTS LOW
g.command("SH X")
g.command("PR 1")
g.command("BG X")
End Sub
'when button2 is clicked perform galil command
Private Sub button2_Click() Handles Button2.Click
'SET INPUT 2 HIGH ALL OTHER INPUTS LOW
g.command("JP #DOORS")
End Sub
'when button3 is clicked perform galil command
Private Sub button3_Click() Handles Button3.Click
'Connect server and start motion
g.command("TI 04")
End Sub
'when button4 is clicked perform galil command
Private Sub button4_Click() Handles Button4.Click
g.command("TI 08 = 0")
End Sub
'when RESUME is clicked perform galil command
Private Sub button5_Click() Handles Button5.Click
'RESUME CODE WHERE LEFT OFF AFTER STOP COMMAND
g.command("BG XY")
End Sub
'when STOP is clicked perform galil command
Private Sub button6_Click() Handles Button6.Click
'STOP MOTION
g.command("ST")
End Sub
End Class
g.command() returns a string, and will tell you why it isn't working.
The simplest way to see what is going on is to do something like:
Code:
MsgBox(g.command("SH X"))
Code:
Thanks i figured it out, i was missing my argument in the button click sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
g.command("SB1")
End Sub
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
145
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
246
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
141
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
965
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
99
