Programming help Toshiba Provisor PMC-S plc
Fayyaz
Jan 2016
Karachi
Dear All,
I have toshiba provisor plc model PMC-S attached to Toshiba Die Casting DC-135-EL model. When I start the machine all the error lights of Plc turn on and i can't start any job. I guess the program is corrupt. if any body can help me connecting plc to laptop and ladder program
Sir, Thank you very much for your quick reply. I have downloaded the manual and found it very useful but i could not find the download link of tcprgos-w file from google. I would be very grateful for your support finding it and plc connection to laptop to upload ladder logic to plc to drive toshiba cold chamber die casting machine.
@Fayyaz,
I found a link, please check your Private Messages. Since you are new to the forum, look near top right side of the webpage for the Private Messages button.
So nice of you for this support. I have downloaded the software and I will connect with my laptop to plc. One thing i would like to inquire that the manual does not show TOSHIBA Provisor PMC-S plc. is it right that TC-200 and PMC-S plc are same. And one more favor i need, do you have ladder logic of TOSHIBA DC-135EL cold chamber die casting machine.
I'm sorry but that is all the info I have. I don't know if the software will work on your model PLC. It is a very old plc.
Ok sir, no worries. I also have T-PDS software and now I have tcprgos-w. I will try to connect and i hope one of these software will definitely work. I have three D-Sub connectors on my PLC two of them are db9 and the one marked as peripheral is DB25. whats your advice. Should i use DB9 (PC side) to DB25 (Provisor PLC side) Cable. Thanks again
@jrwb4gbm & Fayyaz,
Could you give me link to download it. Thank you very much!
I cannot find my original link or an active link that I found with google. If you don't find a link, please send me a Private Message. Private Messages are emailed to me to let me know an additional response is needed.
Thanks for your replied, jweb4gbm!
I've found TCPRGOS-W.exe on Internet. But, my PLC is Provisor B200 so I can't connect to my PLC by TCPRGOS-W.
Help me! Thanks so much!
You haven't said what computer and operating system that you are using. Newer computers may not work. I would recommend an older computer with Windows98 and a real RS232 Serial port. I don't know but I think that TCPRGOS will work for most of the Provisor family.
Do you have the manual STE 71272–0 Setup_Manual to see the comms setup on pages 6 and 7? Since you might not, I am going to upload it here.
Edit:
I've uploaded a Beginners Manual also. It is in three parts. Download all three parts. Unzip them into a common folder. Then, use WinRaR to re-combine them into one manual.
Tcprgos
I know this is a older thread but I am currently looking for the software TCPRGOS working on a TC200 plc running a Toshiba printing press but I cannot find the software on this plc.
Hello, I am working on a Toshiba EX100 that I need to extract the ladder logic. I'm at the end of my rope. Any help is greatly appreciated...
105
74,099
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
1,047
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
2,028
I don't have much experience in programming. I can do simple configuration. it is like this. i want to add something to the existing ladder...
39
6,365
Hello there, I'm practically new to the PLC world, I'm quite familiar with Siemens TIA Portal but I'm currently tasked to program Schneider PLCs...
1,882
