Programming Premium PLC via Ethernet
Schtiel
Oct 2006
West
92
Hi! I have Premium PLC with built-in Ethernet port but I don't have any programming cable.
Can I connect to PLC using Unity Pro and download program to it (without downloading configuration and IP address using, for example, USB cable)?
i.e. does Premium PLC have a default IP address?
Thanks in advance
Hi
the following should help
How do I derive the default IP address of the TSXETY5103, TSXETY4103 and
PORT?
Document Number: RESL168082
Revision: 1.0
Question
PORT?
Answer
The default IP address for the TSXETY5103, TSXETY4103 and PORT is in the
following format 85.16.xx.yy.
The first and second octets are always fixed at 85.16.
The 3rd and forth octets are the decimal equivalent value of the last 2
hexadecimal pairs of the MAC address.
Example Format: 85.16.xx.yy.
ETY MAC Address: 00.80.F4.01.05.36
xx = 05 (hex) = 5 (dec)
yy =36 (hex) = 54 (dec)
Hence derived IP address: 85.16.5.54
Another method is to use a program like BootP turbo to set the IP address from the MAC address (printed on the front of the cpu).
You should be able to find BootP turbo on the web and download for free
We are having Unity Pro XL v5.0 through which Premium PLC is communicated, when I was trying to connect It is not going directly to programming...
4,648
First of all, Good day to all!!! I'm only new here, and a newbie on automation. Now, I'm looking for any help to start programming & diagnostic...
17,969
Hello guys! I am currently working with a Modicon Premium P57354M Processor. I have found the TSX PCX 1031 download/upload cable but I can't...
7,242
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
117
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
903
