really cheap HIM and control
Erik vdH
Sep 2006
NZ
42
I have a customer with a project which calls for a really cheap graphics HMI (pos touch screen) and basic controller. It is for a high end domestic temp controller. Volume will be quite low, anyone come across anything?
Cheers
Remember, cheap hardware doesn't always equate to overall cost savings. You can lose money on development time, troubleshooting, compatibility issues, etc. Its usually more cost-effective to provide hardware/software that is familiar to the developer, ever if it costs a bit more on the front end.
Thanks for all the suggestions, I will look them up. Regarding the contradiction between cheap and high end, I guess anything more than a thermostat is high end for the domestic situation!
I am out of my normal league here.
But what about an "intelligent relay" ?
I think that some have analog inputs, and I also think that some have a small display and a few buttons.
And they fit in one of these enclosures where you normally place circuit breakers in domestic installations.
Erik,
If it is a domestic HVAC system (Heating, Ventilation, & Air Conditioning) then one of your big problems will be how to interface a PLC to the 24 volts AC power common in HVAC controls (here in the US anyway).
There are a few PLCs that will accept 24 VAC inputs (such as the AUTOMATION DIRECT F1-130DR). It seems that getting the proper interface would be more important than the cost. If a cheap PLC will not accept 24 VAC inputs and outputs (or whatever is used in New Zealand), then you are looking at adding a bunch of interface relays and a power supply. Suddenly your cost has gone above what it would be to have bought the right PLC in the beginning.
Local Rockwell distributor was in today. He says that the MicroLogix 1400 will likely be unavailable to purchase sometime around the end of this...
58
16,693
Good Morning , I've taken on a job that is truly over my head with a engineering group. The standards of Rockwell programming is much more...
7,077
I’ve been looking at buying a quantity of signal converters to take a type J or k thermocouple or RTD and convert it to a 4-20mA signal. In...
3,007
Doing some consulting work using factorytalk view studio and RSLogix5000. We set up alarms for the system a while ago and they work fine, as do...
3,648
I spent the entire day trying and failing to setup my 1783-NATR. It appeared, time and again, to be correct and happy but no matter what I did...
5,048
